I’ve Got this kit from @johnny_261 I don’t want to make any mistakes And I have no Key, An Advice?
Read the topic no need to start one for this
I know he does not include Key, But I Overlooked that.
There is no keyway slot on Keda motor so you don’t use it or you need to make one. To secure pulley on the shaft you need to use a file and create a flat spot(s) on the shaft for a grub screw(s). Or/and use some Loctite 6xx to secure it. Also Keda motors have really short shaft, I wouldn’t go for 15mm, depending on the motor mount you will have half a pulley sticking out…
Iv’e bought it, I understand i must file a flat spot for key, But what key will work?
You have the terms mixed up. You don’t file a flat spot for key but for grub screw. You don’t use a key because there is not slot for it on the shaft.
OK I have no Idea about anything about fitting the pulley on the motor,
Your talking about this or something els?
Yes, you don’t have that slot.
I can Create it,
But that Black thing “Key” I do not have,
So is there a second method Or that is the only way?
I already gave you the other way. Flat spots and grub screws + Loctite. Or only Loctite.
For the key, if you can create the slot: products/motor-keyway
I dont know what Grub Screws are, did anyone do your method forum link??
Shipping for the Key is 40$ LOL
You know how and have the tools for making a keyway yet don’t know what a bore,flatspot,keyway or grub screw are?
I’ve googled it but I Don’t get what that weird thing would do.,
I use my dads tools.
And I don’t know all the terms because this is my first time doing stuff like this.
How are you going to make a keyway?
Maybe use a dremel,
Right…
