Hi guys,
Some of you may have seen this board on FB or Reddit, but I needed to create a topic here. This is my first build, the KRG-1. I’m French so I’ll use metric system.
Parts list:
- Trampa Street Carver deck
- Trampa Mini Truck
- Trampa underboard battery tray
- Trampa motor mounts with aluminium tubes
- Trampa HYPA wheels
- Trampa Uban Treads 6.5" tires
- 12S4P (Sony VTC-6) flexible battery with integrated BMS by Kevin Dark
- Street Wing motors 6374 190KV x2
- Focbox x2
- Strongbelt… belts 14x425mm
- 14x66 transmission
- Keyway on the shaft
- UART module
- XT90-S Keyloop
- UNIK 12S 3A charger
- Rear light (https://www.amazon.fr/gp/product/B074496PRB/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
- Front light (https://www.amazon.fr/gp/product/B01B1MHWP6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) with a step down instead of the supplied battery to plug directly to my charging port
- Modified Maytech Remote https://www.youtube.com/watch?v=3Y5U3HCjLfQ
Custom parts:
- Battery undertray ends 3D printed in PLA (both sides)
- Motor mount protections 3Dprinted in PLA
- Trampa dampa 3D printed in TPU (softer than the yellow ones)
- 3D printed concave extension un TPU (awesome if you ride without bindings)
- Custom belt tensioners made with bearings and speed rings
All my 3D files are here: https://www.thingiverse.com/Koringer/designs
Software :
- Ackmaniac firmware
- FOC mode
- PPM + UART
- Ackmaniac app on Android
- NFC chip inside the remote. It launches Strava, Ackmaniac app and Spotify when I put my phone on the remote (and send a notification with “Good ride”! ^^)
The board went through different versions: 1. 2. 3. 4.
