No, that might reach the same top speed as a lower kV motor and higher voltage but it will have significantly less torque. The best setup in terms of torque and speed is 10-12s and 170-190kV. Then you just have to adjust your gear ratio depending on your wheel size
Okai. Iâm sorry, but the reason i keep mentioning 6s all the time is that i plan to build my first board on 6s. I understand that i can calculate the speed with gearing and wheels size, i just wonder if a 280 or a 200kv motor would be best.
Generally higher motor speed is better
Cooper loss on the motor is proportional to the current, if you run the motor at higher rpm and use a more aggressive gearing you can keep the motor torque lower, thus lower current and lower copper loss, so better efficiency
Did you see my response?
I gave you a fishing pole, and youâre still asking for a fish.
Yes i did. According to it i should choose the 280kv motor on 6s. Am i right? It will be closer to the erpm limit. Sorry, maybe im a little slow. Iâm not an expertâŚ
voltage - 6S max erpm - 50000 efficiency - 85% wheel size ? top speed ?
Wheel size 83mm, top speed maybe 20-22mph. Iâm a beginner.
Around about 300kv would be a good match for a 22mph top speed on 15/36 ratio with 83mm wheels and 6S voltage
donât use 300kv lol
use 270kv. I donât recommend 6s on the vesc either. itâs not really the sweet spot. if itâs possible, go for atleast 8s and bump it down to 245kv. as a beginner, 15mph feels really damn fast, if you get bored, just change up the gearing a little bit.
Okay. Thank you for the feedback. i think i know what to buy now.
I highly recommend 10s and 190kv, as it is considered the sweet spot. but if youâre dealing with space constraints or other issues 8s is a bare minimum IMO.
14mph is about where I consider it to be âfastâ when youâre on an esk8. 25mph is fucking flying and 35mph is âIâm ready to die todayâ
5-8mph is a normal speed for beginners
Iâd recommend 10S and 170kv or 150kv but thatâs just me. I like more power/torque/braking instead of top speed personally
i think thatâs a typo, most of us would call that âfunâ
I think i would be ready to die.
