Landyachtz Tamahawk | Carvon Hubs | 6s Lipo
This is my first eSk8 build. The build is still in progress but I hope to finish soon. I started off with a Landyachtz Tamahawk.
I decided to try the CarvOn V2 Hub motors. http://www.carvonskates.com/
I added some 0.5" Khiro Angled Wedge Shock Pad 80A Risers: https://www.muirskate.com/longboard/risers/2081/0-5-khiro-angled-wedge-shock-pad-80a-risers
Finally starting working on this project again… Cut the enclosure so the esc’s can breathe:
Added T-nutz to the deck:
Starting to look like an ESK8:
I still need to get a decent battery but until then I am going to run the 6.6ah Multistar battery I have.
Z.
looking good. really like that tomahawk deck. Are those twin fvt 6s 120’s?
Thanks Jebe! Yes sir those are twin fvt 6s120’s. I purchased a bout a year ago and never completed my build. My second build will have VESC’s.
Whats your top speed on this? How does it go up hills?
I will let you know the numbers when I actually ride this thing!!
man you really going to beat yourself up for laggin so hard!
also a couple of vesc’s on foc and 8-12s will make this next level. keep that in mind when one of those fvts blow, because i’ve heard they will eventually.
I finally took the eskater out for the my first run ever on an eskate! Wow this is this fun! I only cruised around a parking garage with no cars around to get the feel of the board. I Had my lipo alarm set at 3.5v and after about 10 mins of riding it beeped. After letting the board/battery cool down I was able to ride for another 10 mins. This 6.6ah multistar battery is definitely the weak link. I will be saving up for a real battery and most likely some VESC’s.
Added some straps to secure the battery:
