This is completely incorrect. @ZackoryCramer pls refrain from providing input if you’re not sure you’re right. When it comes to batteries, incorrect information =
You got me brotha Thanks.
You may want to read through this: http://www.electric-skateboard.builders/t/new-vesc-user-read-this-complete-walktrough-of-the-vesc/2980
You can set the Start and End voltage.
Wrong, lithium doesn’t self balance, that is on the serial connections, on the parallel it obviously get even voltage in the same group
The main example of self balance it’s lead acid, that when the cells reaches a given voltage it’s stays there and starts to warm to dissipate th excess energy
With lithium if you keep increasing the voltage the cell will keep increasing and then something bad will happen, that’s why it’s recomended to use a BMS at least for charging
If you use quality cells the internal resistance is almost the same in each one, this way the energy loss as heat on each cell is almost equal so no significantly imbalance will occur
Of course in thousands of cycles this diferences add up and the difference can grow to an unacceptable level
Edit:
To make and exception if I’m not mistaken sony had an self balancing chemistry
Hey I concur with you brotha. But @mmaner seems to be getting away with it though. Maybe there are discrepancies we should sort out.
Sure, with quality cells it will take a long time, take @whitepony as example
With greater number of P cells it gets even better, since you average out the differences of each cells by joining them in parallel
Im not arguing that fact, it should only balance within the same group. If its because the chemistry and resistance is almost identical, or because the little battery beasties like me more than anyone else…couldn’t say. I just know that after almost a year its still balanced.
The beasties must like me too!
How do you know the cells are balancing themselves? It could be just that the cells have very litttle difference brotha.
On multiple occasions I have measured each cells beginning voltage before charge and re-measured after charge. It shows that there is up to a 0.6v per cell deviation. After charge there will be, typically, a 0.25v deviation per cell. After sitting overnight the deviations is typically .1v at most.
Strange. The cells seem to have memory of each other. you should record every charge over night voltage difference, because we want to see how the cells progress over time brotha.
I did for about 3 months, got tiring. I do it about once a month now. I will eventually stop recording all together if it stays at the limits I described.
I’m thinking about using a VGA header to make a balance plug and then cooking an enclosure up for a BMS, so I can balance charge multiple packs with a single BMS.
So If I just use the bms for charging and not for discharging I don’t have to spend 100+€ for a 100A discharge bms. I will say my vesc’s they have to shut down If my batter voltage goes down to 30V (or another Voltage). Theorethically I don’t damage my battery with over discharge. Is this right or I’m just retarted? Alex
No, you absolutely can damage a battery with over discharge. You can use the VESC to set the voltage cutoff values, so using a BMS for discharge only is acceptable. Its not the safest, but many people do it because they keep on eye on the pack voltage.
So I have to spend a lot of money for a 120A discharge bms?
No dude, if you don’t let your pack voltage get below 2.9 per cell you are fine. So set your cutoffs accordingly in the VESC and it will cutoff voltage when it reaches that limit. You can use a charge only BMS so that the cells are balanced and charged correctly, and discharge directly to the VESC/VESCs.
Oh okay now I understand, sorry Thank you very much for your time
No worries, let me know if you need anything else.
How are the cells hooked up during charging? Are you measuring directly on the cells or some place along the charge wire?
But the cells do have some recovery, after a heavy current the can take a while to get to resting voltage, that’s the problem with determining state of charge using voltage only, you never know if the cells is at rest or still recovering
