I’ll try to rewire it with some thicker awg wires but I am considering just buying a balance charger or trying out a more reliable BMS setup, if you have any recommendations I’d appreciate it.
5s to 10s balance lead series connector. You can find them on eBay. Makes two 5s batteries one 10s battery to charge with bms.
Did you measure the voltage at each pin of the bms? I’ve got a few bms’s if you need some.
I’ll probably give your BMS a shot. What gauge wire do you use for those? Do you have any spare 5s to 10s connectors? I can’t seem to find them on ebay. Also, I did measure the voltage on each pin on the BMS and it seems to be fine. My issue may just be the 22 awg wire I used so I’ll try that first, and if that fails I’ll try your BMS.
10 gauge. I don’t have any spare cables. Try progressiverc.
I appreciate the help everybody!
