Hey @RyEnd thanks for the response and appreciate the links. I only plan to use the BMS to charge, so I believe that means I want the ‘separate’ port variants? Buying any amperage would be fine right; just impacts the total charge time? Your first link notes ‘lithium battery pack 18650 LiFePO4 Battery Pack’, the cells I own are 26650, any implications there?
Assuming one of those BMSs is applicable, this charger should be fine?
Thanks again for your help, your links allowed me to more fine tuned research.
