Why would anyone still be choosing lithium ion over Lifepo4?
Why are 18650 lithium-ion such as Samsung 25R and 30Q are still so popular if Lifepo4 have these amazing features?
Pros:
More constant discharge rate
Less battery sag
More life cycles
Deliver higher discharge rate
Safer
Faster charging time
Larger overcharge tolerance
Higher working temperature
Cons:
Lower capacity (easily compensated with more parallel cells)
Slightly higher price tag
Cost (which I consider to be more than “slightly”) and availability of genuine cells brought me to Lithium-ion (Samsung 25r) instead of LiFePo4 (A123 is the main manufacturer as far as I know)
This is a way to get them cheaply It might be risky because you never know how many of them are good and how many are bad, but I would give it a try if I had more money
