Hi everybody
I just got the HCX-D596LI12S80A-02, you can see the specs here.
I need to connect it to my configuration with 2 6s battery pack in series, here is the connection diagram from litech website, but I don’t really get it: I’m no expert…
Yes, looks good. I have drawn thick yellow lines where you should use thicker wires, like 12awg. Thickness of wires to charging port depends on charging current, but 18 or 20 awg should be enough.
ok I finally had some spare to time to work on it.
I made all the connections right, I didn’t blow up but it is not working.
I tested connections with a multimeter, I bypassed the BMS switch connecting the two wires, but nothing:
I got no power on the ESC and measured no Volts between + and - on the ESC or the charger port.
I also bypassed the BMS directly connecting batteries with the ESC, and I got power. So Is it the BMS ?
