That looks like a smart move. Not sure if I can rotate the motors given the glue, Hummie mounted motors for me so not sure how they rotate once installed.
If I put Velcro on the outer part of the heat shrink on my VESC do i run any risk of hurting it??? Or do people mount using the mounting holes? Thanks in advance.
I actually prefer a soft mounting solution like this. We see a lot of vibration on eboards and the more you can dampen the vibrations the better off your electronics will be.
Got a present in the mail today!!! I ordered a Spacecell4 on May 4th and DIY battery in mid-June and this battery in late June and received it before the other two!! Will add photos after I install it later tonight!
The battery installed. I am getting about 9-10 miles out of a charge, great battery so far! I also like that I can switch out the battery pack and on off switch and fuel monitor stays with the board.
