Hello, I’m new there. I looking for a Motor mount fit to Racerstar 5056 moto and Chain drive. If it possible M.M. ship from europe. I have Caliber 180 Truck.
RACERSTAR:
CHAIN DRIVE:
RACERSTAR:
CHAIN DRIVE:
Also, why chain drive?
Because I weigh 110 kg I think chain drive will be better.
Are you going single or dual? That one motor will struggle alone
i weight 100kg and one of my boards is running a single 5065 and I can tell u it’s not happy… chain drive won’t help…
I would recommend dropping the pinion down to 12T to get enough torque to be at least usable…
I run 12T/36T belt drive (hobbyking motor mount) on my caliber trucks.
Erv.
Single motor
I have a question. Hobby King motor mount will fit with You now screw hole is 38mm diameter.
Thats a bad ratio 1:2 go with something like 1:3 maybe
You probably would be better off with a 6374 or dual setup
I would go dual drive I am using these motors in my current build and got 2 because you should be using duals if you have a smaller motor unless you are a lighter rider. @marcmt88 makes mounts to fit those motors.
No it’s not a direct fit, only 2 of the 4 motor screws will work. Unless you file the mount down strategically.
