Where do you guys get a case ?
https://www.amazon.com/gp/product/B00BFU50CW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
This is the one I’m using. Depending on how you mount things, I believe it’s just big enough to fit a 12S9P pack and 4 VESCS. I’ve ridden 10km+ through heavy rain without getting any water at all inside. I just have it Velcroed to my deck and can carry the whole board by the case’s handle if I want to without any issues.
Si you have pictures of your on the board ?
like said above, this stuff is nuts!
Do you have a link?
Currenty running 10S9P with 2 FocBoxes. There’s just enough room to fit the FocBoxes above the battery pack if I didn’t have my pack setup so that each series cell is removable though.
got mine on amazon .it or .de don’t remember
yep, thats the one im using as well. im bolted some screws though its frame and stuck in onto my board with velcro.
just to understand if I´m right @Achmed20 you use the 500 version and @michaelcpg you use the 1000 version, right?
If yes than that´s nice to have them here next to each other to compare. Thought the 1000 is a bit more going over the edges. But like this it looks still nice fit.
jup, 500version, i like using Lipos since they are easier to swap. And my 2 6s 12Ah Graphnes fit just perfectly in there. Had to modify the case slightly and get rid of a few dimples, ridges and the pressure vavle sicne they were cutting into my Lipos.
fit like made for it! I have 4 heavy duty 5ah. they to high to place them over each other and a bit to long to place them next to each other. so I guess I´ll need to go with the bigger one in case my 3D printed boxes don´t do the job.
mine didnt, thats why i got this one
molded ABS is still way stronger then every FDM print could ever be
may I ask you what range you get out of your 12ah packs?
16km offroad/woods and about 20km on streets.
No BMS? Are you using a balance charger?
Not currently.
I regularly check the voltage of each cell and don’t charge above 4.1V or below 3V though. I’ve had the board for about 5 months and all cells are still within >0.01V of each other
Using good quality Panasonic cells probably helps a lot
I use the Pelicase 1150. I would choose the case according to the size of your batteries + padding.
are you in the states? i just ordered a pelican case through google express. $15 for the Type 1000
https://express.google.com/u/0/product/945555965360916694_2368379859461999431_6136318
