I used one these 60a welders to weld .12mm strips. I set it on max current and 8 pulses I tried to use the extension electrodes but the length of the cables reduced the output too much so I ended up having to ditch them and just use the arm mounted electrodes. Tip: inspect and clean electrode tips often. I used a very fine file to clean mine.
Thatās been my experience as well. I aim a fan into the vents to clear heat when Iām welding and that helps. Overall, though, Iāve had to go slowly with my 788. You canāt weld a whole 10s4p all in one sitting. Iād say I do about 30 welds and then let it cool down for 5-10 minutes.
You mean blow something in the welder itself?
Yes, the parts that control the flow of current in the welder. The issue seems to be more prevalent in the 120V models and not the 240V models
how much of a break should i be giving my welder?
I think what tree nutter said is correct. Like 5 to 10 minutes to cool down.
Hi @willpark16 I had a 709a time ago. I hope I can help you.
0.10 adjust 1-2 and 3-4 for pen 0.12 adjust 2-3 and 4-5 for pen 0.15 adjust 3-4 and 3-4+4p for pen 0.20 adjust 3-4+4p and 7-8+4p6p for pen 0.25 adjust 5-6+4p canāt use the pen 0.30 adjust 7-8+4p canāt use the pen
Those are the settings for that machine. Regards
Thanks man
were these settings for 110v or 220v? I only ask because i had to double your settings on my 709A on 110v.
220 V I live in Europe.
So for the US. Whatās a reliable pen style spot welder under 300?
sunkko basically. not the most robust machine but for smaller scales it works.
most are using the 788 or 709
My experience with arduino spot welders has been flawless so far.
https://malectrics.eu/ https://endless-sphere.com/forums/viewtopic.php?f=14&t=89039 https://endless-sphere.com/forums/viewtopic.php?f=31&t=81274&hilit=6pence&start=0 https://endless-sphere.com/forums/viewtopic.php?f=31&t=68865 Build your own: https://github.com/KaeptnBalu/Arduino_Spot_Welder_V2 The one I use: https://www.electric-skateboard.builders/t/boss-level-custom-spot-welder/ Also I had a sunkko 709a some time ago and I was very happy with it but I need smaller solutions so I prefer arduino.
I need help with welding a 4x5 battery pack 18650. Looking for an owner of spot welder in Los Angeles area. Iām living in Irvine but OK to drive 1-2 hours. Some appreciation is on me.
psychotiller is in your area, ask him, maybe you can save yourself a drive to LA.
If not i got weldersā¦
Anyone here have one in the SGV area? In Riverside sometimes too. Or else Iām gonna get a Sunkko.
