Hello, I have been having an issue when I use the brake, first off it seems it takes forever to brake and second if I keep it long pressed it like stops braking ( you feel the snap) then if you let go of it and brake again it goes back to braking. Anyone has had this issue before?
For harder braking you should set your motor min to -60A… that max and min settings on motor are to limit the power that the motor is using to turn “forward” and “backward”.
Looks like you need to update some of those settings. You’re ERPM values are screwed most importantly. I have a 10s and here are my settings.
Motor max 60
Motor min -50 (if the brake is too powerful reduce it, if too weak you can go up till -60)
Battery max 30 (if the board is too powerful reduce it. Depending on the type of batteries you can go up.)
Battery min -10 (correct would be -8 but to have some space in times of crisis)
Min ERPM -60000Max ERPM 60000
Battery cutoff start 30
Battery cutoff end 28
At -30 Motor Min your brakes might be relatively weak. I use -45/-50 most of the time with my 83mm wheels. When I put on my MBS 100mm I need to use -60 or the brakes are just too weak.
