If you adjusted anything on your remote like the trimming option to achieve 50% in the BLDC-tool before, make sure to set these back. Otherwise you wont get 50% while trigger is in resting position.
Your full brake and full acceleration ms values the receiver sends to the VESC based on your controller input needs to rest at 50% or idle when you are not pulling the trigger. Usually the progress bar on Ubuntu shows the actual percentage in there with yours it appears to just be a line basically so will be harder to get the value right. Full brake should be the minimum ms value though and full throttle should be the maximum, in theory when you let go of the trigger it should go to idle. If it goes above 50% when you let go then your high is too low or your low is too high (the middle is therefore too high), if it goes below 50% then your high is too low or your low is too high. You can also adjust the deadband which is a perecentage around the 50% mark that it will consider “dead” or idle, to get it to accelerate or decelerate you need to pull or push the trigger out of the deadband region into the “active” region.
That’s weird since @Ackmaniac’s PPM wizard will set the PPM min/max higher and lower (respectively) than my actual values. For example, my remotes actual min is 1.10 and max is 1.96, but the wizard sets it at 1.11 and 1.94
I think just slightly past still works but if its a lot past the vesc will think the signal is lost and cut out. I prefer my remote end points to be just inside the PPM BLDC end points for added safety.
