My psychotiller lost a set screw on the motor pulley. Can I still ride until I get one in there if I watch it?
Depends. Did you put loctite?
Are you using a key in your pulleys?
if you are using a key then yeah you can still ride just maybe put a little bit of loctite on your motor shaft so that your pulley doesn’t slide off
Dunno what a key is but the screw was found! On my motor, the magnet snagged it for me!!!
use loctite…
Basically
Your best friend…
…anything else will be uncivilized.
Thanks everyone. Learned a bit about motor pulleys yesterday. I appreciate you all.
