it certainly is more massive then the usual ebay hub motors.
Motor is running fine and does not have much miles on it since I was just testing it and swapped it out on my Lou board. Wanted to look under the cover and accidentally round off one screw, used the Dremel to open it. Just a cosmetic blemish.
yeah its a shame that they don’t sell it individually. Whatever china factory this thing comes out off they could make like a gazillion dollars with it. What sucks though is that only a 1P battery fits - this really limits usability.
I am pulling 20A from the battery with my Focbox and the sag is like 10V.
Apparently it was Winboards design. They’ve come out with another iteration of this design which is not as good looking as this the Lou board “founders” seem like clueless people whitewashing everything e-mobility…
@Maxid are you still running the standard pack ? I did not get to build the new pack with 30q yet. I avoid riding the Lou until I have time finishing the battery. The stuff inside the enclosure is rattling like crazy making it quite annoying riding it… might have to use some kind of dampening
Yeah I am - I am debating with myself whether to go 10S 30Q or even 12S (and ditch the BMS) or go 20700 Sanyos. But then the weight will be increased even more
1P really sucks - braking is super weak and oh my the voltage drop. I can’t believe anybody is actually able to ride this thing in its stock config - I am already disappointed with it and have a Focbox inside.
But I can’t bring myself to switch out the hub motor - it looks just so stealthy.
I think it’s around 50Kv.
I think a 12S vesc and these will be pretty good.
Edit: it’s for sure 60Kv, I swapped the batteries recently with VCT6 cells and now topspeed is 33kmh on the lou 1.0
