Hey !
After lots of readings about batteries, cells, BMS… in order to build my own battery for my LouBoard, I still have some questions to ask to you.
I’ve chosen Sony VTC6 batteries because they have high capacity, higher maximum discharge current than my previous battery pack and I can buy them from a local supplier. Sony VTC6 have followed characteristics :
- Maximum discharge current : 15 A (without temperature control) / 30 A (with temperature control)
- Capacity : 3,12 Ah I will organize them as a 10s configuration.
I have a charger which is 42 V and 2A continuous.
Thus, I need to choose the right BMS. I will take one from Bestech. Here’s my question : I’ve understood that in most cases, BMS are used for charging and not for discharging; So should I consider the Maximal continuous discharging current when I select a BMS? If yes, does it need to be at 30 A or higher (as the maximum discharging current of VTC6 is 30 A)?
Also, most BMS have a Maximal continuous charging current around 6 A or 8 A. Does it mean that I could buy a new charger which will provide more current (my current one is only 2 A) ?
Thank you all for your answers
