I have started to make a 12s7p battery pack for a top mounted pelican box on my trampa.
So far hot glued 3s7p.
I have positive isolation ring and I cut strips to cover bottom and top on sides. This to protect the cells if they rub against each other during riding and letting me to glue cell to cell.
I will use 25x0.15 nickel strips to cover parallel and series connections. Connection to the pack will be 12.5 mm nickel strip and 6 cables going to one 10 awg cable.
I will use BMS for charge and discharge (Bestech D596), though it might be good to have that protection for my first build.
Now waiting for arduinos spotwelder, kapton tape, and 8959 scotch tape to arrive.
Please comment by build if you like, I appreciate both positive and constructive feedback.
I put the nickel strip on top of each other on the picture to simulate what it will look like.
I won’t do double strips since I do not like the idea of a gap between the strips between the welds.
Im pretty sure that you will not ride your board on -22 lol
and even if you will your cells wont ever be that cold unless you leave your board outside, temperatures below zero can damage cells
Timing for nickel to steel and nickel to nickel will be different, and everyone’s setup will yield unique timings. So just practice for both then go for it.
But the test welds on the cell, that looks over cooked, back it off a bit.
The nickel to nickel test though looks ok, maybe back off a bit so it doesnt create a hole.
I have no experience welding, but I would say that a pentagram shape (one on each star point) would be a good one for welding, enough welds, good placement to prevent stress ripping so it’s not weak horizontally or vertically
I dunno if that plays a big part in it, I’m just theorizing
