im not intrested in a vesc since i am on a very tight budget
No. You would only have 4 teeth in mesh on the 10T gear, which is terrible for torque transfer
Ok thats unfortunate better go for 30T:15T
Iâve found a 48:16T pulley kit and the 48T pulley is only 51mm diameter so I will be going with that
wont fit with a 56mm wheel
theyre 59mm so i should have 5mm between the ground and the belt?
The belt alone adds another 6mm. Trust what everyone is saying, youâre wheel is too small.
the belt is not 6mm thick. the pulley has a 3mm pitch
I donât think you realize how small 5mm isâŚ
That caliper is set to 5mm, my finger for comparison
YOU NEED BIGGER WHEELS
I mean 3mm each side, but I guess the top clearance doesnât matter. Itâs your money, but youâll be burning through belts, and probably pulleys.
51 vs 59 = 8mm . You will only have 4mm groundclerance. And thatâs without a belt
I have a measuring tape in front of me ik what 5mm looks like
How? please explain
Because your clearance is nearly non existent⌠weâve been over this.
how much clearance is good?
Your belt will be dragging on the ground half the time. You will go through a belt about every 5 minutes of riding
~20mm or more
Ok so will a 42mm diameter pulley be ok???
Ok, i see. why do you need so much ground clearance?
