Nice looking build can’t wait to see this in action
@longhairedboy here’s that load tester you wanted lol, just apply the brakes for varying load. Sorry for a bit off topic
Well the good part is… You can buy it from eboosted soon and it can be yours too.
A hand on the tire is easier… Brakes to strong… Gotta think about the size difference…tires won’t spin that fast
13S is fine. I am running that but you do get VESC shutoffs when breaking at high speeds at full battery.
Hey, are you still looking for two 6374? I’ll get you them for $200. PM me for details:grin:
So
Got the metroboard cnc’d pulleys in… They’re really nice quality… And one of the few available that are PRESS in for Flywheel style hubs
As you can see it came with 8 ID x 10 OD x 28 L mm spacers. This isn’t going to work with SurfRodz. So I’ve ordered some 10 x 12 x 14mm “bearing support spacers” off the interwebs that I will double up on to make a 28mm spacer.
For now pressed.
Eboosted still working away at making beautiful enclosures.
So got a couple spacers in. The 10id 12od we’re to thin so I’m sticking with some nice brass 101414 spacers.
Stock metroboard spacers next to the new ones. Planned axle setup
Hole to small Drill bits
Widened to 15.9mm with a drill press
Widened with the new spacers and axle inserted Bearing in.
Press on metroboard pulleys on 10mm axles(SurfRodz). Success.
Anyway @Eboosted has finished the final enclosures. Just waiting for delivery.
And @akhlut is almost done with the brackets
Things are getting together. I have the aluminum, will be milling the motor mounts next weekend.
how are you progressing with your build? i’m curious to see how you’re going to set up your charge port, battery meter and power switch.
Well it’s yet to be confirmed
10char
you got any extra spacers for 80mm axles?
I’ve got a couple, not sure how many.
Or you can get these… Khiro 10mmX10mm Bearing Spacers
that link is exactly what i needed. thanks
@mikenyc I’m sorry my sister in law couldn’t take the enclosures tonight as she is going to take 24 hours jumping between airports and it will be an additional weight she won’t take, but my GF will fly tomorrow night, so the enclosures will be in NJ by Friday night.
@deckoz my mom is back in DFW she will ship your enclosures tomorrow along with @Mikenopolis zenith with his enclosure bolted
Mine too?
Yes! Everything will be shipped tomorrow
ooh we can get them pre-bolted?
I wouldn’t drill the enclosure without the deck, you need to do our with the deck in order to have perfect matched holes.
oh i was talking about the spud. i’ll stop hijacking this thread now
