I am trying to calculate the max current I will need for a dual 8072S build. I’ve got a few different configurations and not sure which will be the most the demanding. The motor is rated for 6kW and 95A max, but I doubt dual would mean my batteries should supply 190A. What would typical draw look like with the following configurations?
Those trampa builds usually are big money with 8000x motors and if you got a escape and want the desired amps go Lipo route but get tattu batteries there like the best thing that happened to 8000x motors
Sorry, I should have been clearer, will 12s4p be enough for a dual 8072S build or do I need to go higher? I’m thinking that if I build my own enclosure, I should be able to fit a 12s5p on the Carver without doubling up.
If I were building it with large motors like 8072 I’d go for sure with 5p or higher. You can limit battery amps per vesc to not exceed what your battery can put out. Then set motor amps to 95a each.
I don’t ride as hard as you guys, but once when riding my evo in the dirt going uphill I hit 52a. That’s the highest I’ve ever been and I’ve tried to make it go higher and just can’t.
