Hi,
I want to use this motor and it’s just for a 10s battery but I want to use a 12s battery pack. If I just go up to 60Amps could it also work?
Motor with 3200W
50,2V(full charged 12s pack) × 60A (max Amps) = 3024W
Still under 3200W
Could this work or should I never go over 42V (full charged 10s pack)?
As far as I know maytech vesc’s have the ERPM limit of about 60.000 Erpm.
Most motors have 7 Poles so you have to divide by 7 and get 8570 rpm.
The Motor has 200KV so 200RPM per V that equals 10.000 RPM at 12s (50V)
So at the top end you are pushing your Vesc to an area where they are prone to failure.
Its why I am selling 170KV 6374 Motors as they will not break most people’s ESC’s.
I just like that kind of conversation. I’m no native english speaker, i ment its awesome not crazy:)
Sometimes you don’t see the forest because there are to many trees. I just want him to buy your motors:D
You speak german too, bimmer is probably out of range^^
I can recommend APS, has almost every kv you want or can order them for you, also his motors come with sensors if desired and all i got have silicon wires.
With DHL and a small reduction in price my motors are the same price as APS while being plug an play for vescs. Sensor is already 2mm micro jst and at 200mm better suited.
