Whoooaaa how does that even happen
I finally was able to upload this firmware to my ESCs, unfortunately they started acting weird. Iām using nano remote and I think this may be whatās causing this problem. So, when I fully break and then rapidly release throttle lever, ESCs for second recognize that as full throttle. After fiddling for many hours with throttle trim potentiometer (itās almost completely turned to max counterclockwise position, ESCs take a while in this trim position to notice receiver and start), and setting neutral range to 3%, I donāt get this strange full-throttle-while-releasing-break action. Something like this has never happened with the old firmware.
Hey @squad, This issue is 100% related to the winning/nano remote. I believe someone did a tutorial on how to fix this. The other solution is to get a hobbyking receiver and bind to it. The hobbyking receiver has worked for me.
Iām amazed at all the camaraderie on this forum!
Check this procedure to fix the nano behavior http://www.electric-skateboard.builders/t/2-4ghz-nano-remote-in-stock-30-pcs-usa-50-free-priority-shipping-international-45-shipping/5017/83?u=kaly
Thanks for reply, but I already did that few times, didnāt help. Iāll probably try with another receiver.
Would this with with the 6s version?
Donāt think so
Noob question, does this ESC work on a 60kv-100kv range hub motor? Letās say hummies or TBs hub motor? and how do you adjust the settings on a computer? Do they provide a program file or something and you hook them up with a usb?
Hello! I have this ESC HV 12s from Alienpowersystem.com. I have the same problem about the brake power. Do you think that your firmware is compatible with my esc? thanks for your help!
@Mikeomania12 do you think itās possible to flash my esc with your firmware? And If I want go back on my old firmware how can I do this? thanks a lot
nobody to help me?
Hey sorry for the late response. I cant be sure and dont want to be held responsible, But the software on the computer looks identical. I Think it should be ok since all of those are made by the same FVT. Also maybe contact FVT directly, they are pretty responsive they can answer if you donāt want to try it.
Hi! No problem. Itās ok we can use your firmware on the Alien HV 120 ESC! itās better beacuse the 160606 Alien firmware dont work, there is max brake always. Thanks for your help!
Where can I buy this esc? I am looking this esc up on their website but i cant find this one. Can you link me pls?
Hey man, What do you need to flash the firmware to the ESC. I have two that run the wrong firmware and have just been sitting here for a year.
@Factory72: You have to send an email to bruno, on the website Alienpowersystem and ask the āESC HV 12s with fanā, it is not on website directly. price approx 100euros
@monkey32: You need just the software Setup_HighVol_SCT120A_151014, you can find it here: http://alienpowersystem.com/downloads/ You connect your esc to your computer by the USB adaptater, power on the esc, you click āupdateā, you select this firmware : http://www.nyboards.com/HighVol120A_SkateBoare_161122_portCar150728_best.hgm DONE!
@Mikeomania12: Hi! The firmware itās perfect but I feel that the maximum speed is clamped. And you? thanks
