Jesus pin might not be a bad idea. I have been thinking it would be a good idea on truck axles and mounting bolts too. Bring everything up to motor sports standards.
I fly electric model airplanes and some times crash straight into the ground. The planes that had 8mm motor shafts did not break or bend the shafts even when hitting the ground straight on at high speed.
The increase in shaft diameter is not an attempt to prevent bending or breaking. We are attempting to deliver more torque and increasing the shaft size was determined by projected loading.
The torsional stress at the mating point between the pulley and shaft at 8mm is much greater than 10mm. We are also using larger pulleys than most people use which increases the torsional load at this point of contact.
Old thread. How is it going with this 10mm axle ? Did it come as a standard now 3 years after ? I dont see any Maytech motors with 10mm shaft anywhere, even the big versions of Maytech are still on 8mm shaft. So this hype of 10mm wasn’t really validated throughout but just a marketing trick…
