will using covered water resistant motor give me problem with temperature because its not getting enough airflow? i plan on running 10s3p batteries…likely not pushing board to max…plan on maybe going…30km/h which is about…18 miles/h.
You should be fine. Are you running a single motor? More chance of overheating if you run a single on hills and are heavy?
nah running dual, less load on each motor, should be ok?
You should be fine. The battery can’t really push enough amps to overheat those motors.
