Do any of you guys know the size the 6355 sealed maytech motors use? I would hate to have to tear down the motor and then reassemble it just to find out the bearing size, so if anyone of you kind gentlemen know what bearings I should buy, I would really appreciate it.
688z iirc.
It is 698zz. I sent an email to Maytech and got the answer 9 minutes later
hey guys, so the bearing at the front of the 6374 motor was 698zz indeed. Someone knows the size of the bearrings in the back? Sadly there is no information on the bearring? thaanks
Whatβs the ID (inner diam.), OD (outer diam.) and thickness? You can get the bearing model with those numbers.
