Looks like the instructions on an ESC with a program switch, which, I assume, these do not have.
To anyone using the Maytech or FVT 12s 120a ESC: Make sure no throttle input is given on start up. I have fried several of these by accidentally giving a little throttle while turning the ESC on.
So, I got 2 of these for testing. The wire closest to the sensor port is A, middle is B, and the furthest is C. I am overly impressed with this speed controller. I just have one problem. The brakes are progressive when I brake, but after about 1 second they go to full brake. Do you have any pointers?
Cześć Lukasz!
I have two of these motors on my EMTB but i am waiting on my ESCs to be able to test them. Unfortunately i wont be able to use the sensors as the ESCs i am getting do not support sensored motors. Once i have tried them out i will let you know how they are
Hey @JLabs, there is no way to set the brakes differently. The only thing you can do is change the delay time when it goes to full brake.
Another reference for the phase wires: The one across from the positive lead is A, middle, B, and the one across from the negative lead is C. According to FVT.
Yup. If you have the right version. I’ve only had the USB link work for me. If you change the break percentage it changes the delay, on certain firmware versions. Some make no difference. That and the throttle at start-up death are the reasons I am not running one of these anymore.
Siema:) i got dual 6355 motors sensoredless on VESC and 16cLiFepo4 setup. But the starting is annoying the motors just shaking but when it start is accelerating no problem. I was thinking to try sensor system and bigger motors. Waiting for news from you how they work thanks
