I will print after the weekend, my fiancé birthday party is tomorrow so i dont want a pront running when people are drunk
The distance between axle rim center to motor axle for Janux mount is ~85mm.
Any news with theses pulleys
New off the press more details available here: https://www.janux-esk8.com/product-page/pulleys-to-fit-bms-rockstar-pro-and-rockstar-ii-hubs
Where are you located ?
San Diego, CA
I have the files but never printed them as I don’t have mbs hubs.
Do you have an IGES are STEP file for the 66t pulley?
Not yet, but no problem to export the files like that.
Most of the files I found are in slt, I just don’t have the no how are the software to convert it to get the dimensions.
I think i posted it already somewhere else, but with this two pictures you can design every htd5m teeth pulley you want
The only thing you need to know else is the bolt pattern from the hub you want to design them for.
Theres a generator on onshape, I use that.
Thanks guy’s
Could you send me the .stl file for these please my 80t pulleys are too big.
Thanks
those not mine but there two on thingivers which could work for you as well:
for the pro version
