Hello! I am wondering if someone can help me. I have a Meepo V2p board and i bought a 12s2p battery from torque boards. But after installation the board turns on but thats it. The transmitter turns on and it seems to pair, but does not do anything when i oush or pull of the scroll wheel. I am wondering if i am missing something or if the ESC is programmed a certain way that does not allow it to send 12s voltage to the motors. Any helo would be much appriciated
I don’t think the meepo controller can do 12s. I think you killed it lol
No after i plugged the old battery back in, it works fine.
Meepo ESC not suited for 12s. Suggest you get a 6.6 dual, Unity, or a pair of Focbox.
Thanks. Reason im confused is because others have done this mod and it workes fine.
ESC could only run 10s, 7s, and 6s. Gotta get a VESC
I think ppl that did the 12s upgrade did it with the old meepo esc. I might be wrong. The eac you have is the v2 eac that came with an enclosure.
Yes, its the ESC that came with the enclosure. And yeah i just realized the people that did this swap did it with the old ESC. Just ordered a flipsky dual 4.20 VESC
Sorry to be the breaker of bad news but the flipsky 4.20 dual are known not to be reliable at 12s also your going to need a remote with a reciver to use with a vesc.
Oh?! Lol i cancel the order. What would you guys recomend?
Focbox Unity or flipsky 6.6. i would recommend a unity in your case as it has an antispark built in. Or u can wait for the flipsky dual 4.20 plus to come back in stock as it is much more reliable at 12s and has a built in antispark.
It’s no longer a simple battery upgrade anymore. Battery, vesc and remote why not change hub motors to regular out runner belt gear system while you at it.
Yeah i might as well at this point lol!
If you are looking for a remote. I just designed to and built a very dependable rc remote with built in LED light. I am taking orders now.
Is the battery fully charged? You might have some luck draining the battery to less than 50v.
Otherwise get the unity or two focboxes and antispark and build a loop key in there too.
What do you think if i get the flipsky 6.6 dual?
I haven’t tried it myself but others have had success with it. Same goes for the 4.12 single.
I tried the 4.20 dual and that’s a no go if you want to pull anything more than 29amps on foc.
Awesome! Thanks man! Ill make a post about how it turns out.
Hey, just buy a dual fsesc
This is what i got and i got their transmitter and reciever
