I have the old metr laying at home. Will this works with the unity?
If you want to get the pro version, I donāt mind to buy yours in the next group ride
Posting here for posterity, but for people wanting to use Metr + some other uart based peripheral, hereās the link to the firmware file with internal ports running at 115200. This also has the low speed braking fix.
https://drive.google.com/file/d/1Ng-Gk0CU3XOB-D-ocXVkNCycbUTCykwM/view
Hereās the pinout
This specific firmware is supposed to have UART2 enabled at 115200. Iām unsure if UART1 is running at 115200, it may still be at 9600.
Saved! Damn thanks a bunch. All these knowledge little crumbs youre laying around are starting to come together in my head
Haha, i have also some boards running with focbox. So I can still use that in my other boards
Can anyone help me with getting telemetry with a unity. I have the baudrate set to 9600 in the unity tool. I also made sure the metr was running the latest vertion. Metr shows as being connected but not seeing telemetry. Thanks !
Change the baud rate to 115200 and it should work, I believe.
Tried that, still not working. My green led is flashing so looks like itās a baudrate issue. Anyone know what it should be set to ? Any other settings that need to checked ?
Thanks to @sofuās build thread including 2 additional UART Ports I am pumped for this. If you can use the same pins (I Think their female , which ever one goes in) then it really is an easy swap on swap out.
Can you please tell me what kind of a port it is for the external antenna? I got the module without it and wanna get one, though donāt know what connector to look for at the end.
Where do I sign up for this?
You wait until he releases it
I know. I was just showing my excitement about it.
Finally got my unity connected. Iāve got it set 10s. Can anyone tell me whatās going on with the battery voltage ?
Youāre not showing voltage in this screen shot. Percentage doesnāt always add up. Whatās the actual voltage showing?
Add the voltage so we can see it. Like this. I have mine right below percentage.
Learn something new everyday. Didnāt know I could hold down and have those options !! How do I make it bigger like the rest ?
Hold the colored frame of the box you want to adjust. Then it can be moved and sized. Lit frame to show, dim to leave out of display etc.
How did finally get the unity to connect?
Make sure you have your Metr updated. From there I just set the baudrate and enabled UART in the unity tool.
