Ok so I am selling parts to fund my next build, all of them are used but still very functional. I am in the US, so I would prefer to ship within the country for minimal risk of damage to the items.
If you want reference to see the parts in action, my build thread can be found here:
Pictures:
Items + Prices in latest post
MiamiElectricBoards 8s 120A ESC
-This was pre-programmed by @oriol360, has worked for 6 months without issues. I will include the usb programming cable as well in case someone wants it. He doesn’t sell these anymore, but they are totally silent and well made
**ChiBoards Battery 1 **
-This is a custom 6s 4500mah 60a 99wh battery built by the man @barajabali himself. It runs like a dream, is perfectly balanced, and is airplane legal
**Chiboards Battery 2 **
-This battery is the exact same as the one above, but with one cell slightly weaker than the rest. If you put the batteries in parallel on an efficient board, I’ve found they’ll still put out a full 9 miles of range.
**@Psychotiller Enclosure with 6s voltage meter, MEB 6s one plug charging port and anti-spark **
-This thing is absolutely beautiful, no scratches, ports dremeled out where needed.
-Dimensions are 7.25 x 7 x 0.5 inches
-This will fit both batteries, or one battery and the esc for a functional one plug system without taking the batteries out for charging. Keep in mind, you will need to cut partially into your deck to use this as it is meant to be stealthy and is not very tall
@itsmikeholland The batteries themselves do not have a bms - however the Psychotiller enclosure includes an MEB adapter so that it’s only one plug to charge the battery
Battery one will take you about 3-4 miles with an efficient system. I managed to squeeze 4.5 out of it once or twice, but I only weigh 65kg and it was on flat land. I’d prefer to sell the batteries as a pair, I can give you a discount if you want the second one as well. Put them in parallel and I got around 7-8 miles
