My primary goal behind this board is for it to be travel safe (airplane), ultra portable (attached to my back on a motorcycle),
Airplane Concerns First off, I’m aware of the battery issues with airplanes. My goal there is to have my battery setup modular so I can easily separate it into distinct “batteries” that are under the 99Wh limit and be stored in lipo bags. So batteries like Zippy 6s 8000mAh are out.
Speed & Range I do not need high speeds nor huge range. I’d be happy with 18mph max speed and 3-6 miles of range. I am going with hub motors because from what I’ve read it seems those are best if you plan on manually pushing the board on occasion, which I do intend to do. I want the powered mostly aspect for hills, both up and down (braking). But it would be nice to have a couple of miles of juice in there still.
Budget My budget isn’t a huge concern. I don’t think I really need to spend over $1000 to achieve my end goal, but I’m willing to go up to that. I want the best solution to my needs possible, whether that’s building a custom battery or buying pre-created packs. Though I probably won’t be machining any parts, so I’m stuck with off the shelf there.
Self 5’11" & 165lbs
Rough Build All of that being said, my current build looks something like:
22" Mini Cruiser Board (off brand penny) - 27cm x ~12cm usable space between the trucks.
Longboard trucks for added stability at speed (current trucks get wobbly at ~16mph)
TORQUE 75kv Hub motor (Not sure if 1 or 2 yet)
VESC
Unknown battery configuration (details below)
Battery Details I’m not perfectly clear on exactly what battery specifications I’ll need to reach my goal. Based on things I’ve seen around here, it seems like I need to be delivering 20-30C to each motor. If that is true then I most likely need to be doing 2p with 20C discharge batteries (if I do 2 motors). But then how much in series I need is unknown for me. I haven’t been able to determine how to translate series quantity into speed, etc.
Questions My 2 biggest questions right now are:
- One motor or two? From other posts I’ve gathered that one motor usually tops out around ~12mph on average it seems, although that’s been for geared, not hub. If that’s true, I would want to do two, but I don’t need all of that speed they are capable of.
- What is the minimum battery configuration I can get away with? Is something like 8s2p, 16000mAh total, 40C discharge adequate? Will 8s give me enough? Do I need to go to 10 or 12? Alternatively, if I am using 1 motor, can I get away with 12s1p with a 20C discharge? I just haven’t been able to get definitive answers on this. Is there some simple calculation I’m missing that would tell me exactly what I need based on my desires?
Thank you in advance for any/all assistance you can provide. I’m ultimately trying to get this board completely built in the next 3 weeks.
Photos: Board: https://images-na.ssl-images-amazon.com/images/I/61Mr3MFjCCL.SL1001.jpg
