So after reading every thread about this and watching all yt videos i still didn’t menage to pair this piece of ****
I turn on the board, vesc connected to 2nd pin binding plug in 4th
receiver starts blinking fast indicating that its in pairing mode
i turn on the remote with bind pressed, receiver changes to blinking slowly
when i turn the remote on and off it changes to a solid blue indicating its paired
but the remote keeps on flashing fast red…
its like its only half connected
when i press the throttle the vesc tools says the pulse width is 59-56% jumping between numbers
and when i let go of the throttle its 56% and stays that way
the remote is new, never used, got it as a replacement for my smashed benchweel.
After spending 3 hours on this im seconds away from smashing all this with a hammer:rage:
its kinda sad, finally after a long time i finally am able to work on my board, all i had to do is to set up the vesc and screw on the enclosure and this crap wont work
well its a good sign your registering ppm inside the vesc tool. i take it motor detection was good. not very familiary with that remote i using winning and benchwheel. maybe you can summon the @Namasaki
try chanting really hard out loud
I plug vesc in ch2 black wire on the left
binding in ch4
turn on the board, reciever starts blinking rapidly indicating its in pairing mode
i turn on the remote with the bind button already pressed, it also starts blinking rapidly
then the reciever goes to solid blue indicating “in operation” as it says in the instructions
but the remote keeps on flashing rapidly (indicating its in pairing more)
and thats it…
i put the ground wire on the left side like in the instructions
i burned thru 4 receivers somehow already before this one i guess we just do not like each other
when i turn off the remote the light on the receiver goes to “waiting for signal mode”
and when i turn on the remote it changes to in operation mode
but the remote keeps flashing rapidly like its in pairing mode and the ppm tap in vesc tool stays on idle
I was just thinking along the same lines as @deucesdown
Try som fresh batteries.
Do not use rechargeable AA’s
Because there output voltage is only 1.25 V
Use alkaline or Lithium AA’s
I use Lithium and they last a long time.
