I am using two (most likely identical) Enertion 4.12 VESC’s in my dual motor setup. I have set up the VESC’s according to the recommendations given for a setup identical to mine. All works brilliant and I have already used the board for a couple of km’s.
Here is the thing. Both VESC’s coming out of the same batch, one of them lights up a blue LED after that three red flashes and the other one lights up a red LED. Not sure why the VESC’s behave different??? Should I worry that the red LED VESC will sooner or later fall apart???
Here we go. Bit hard to see but VESC 1 only lights up just the blue LED and VESC 2 lights up both.
I set up the VESCs individually and had this issue since they came out of the package. In the dual setup I split the RX signal.
