Module 2 Straight Tooth Spur Gear
Precision Milled Gears for production. The wheel gear will house a 6006 bearing and will be made from POM or nylon , have not decided which material is best. And the motor gear will likely be made from Stainless Steel
Options to change gear ratios - 4.4, 4, 3.7
Rotary Encoder - Similar to what Jenso has done
Prototypes on the way and being tested by a few people
MBS Rockstar - and other wheels with the same bolt pattern
Trampa Superstar - and other wheels with the same bolt pattern
Sixshooters
Haggy wheels
Moon MK16 Hubs
Designed to fit the following trucks
MBS Matrix II
Trampa Vertigo/Infinity
Surfrodz RKP TKP
This looks like it will be really cool!
Do you think your kit will have a way of using haggy wheels with the matrix 2 trucks?
Iโm guessing not (because of axle size) but figured it couldnโt hurt to ask.
Cool,
Iโm sure you have a lot of testing and finalizing to do but if all goes well when do you think you would be in production and ready to take orders?
Thanks
Finally
I think the fact that you can use one gear drive with different trucks and hubs was missing long time here. No need to spend an arm and a leg if you decide to swap out some components on your board.
Really hope you get the AS5047 Encoder integrated in your gear drive. The encoder seems to bring a lot more control over start up traction. Next level and should be standard for all e-mtb in my opinion. Unfortunately I see it way too less used here.
Is this going to be targeted towards mountain use or on/off use?
4.4 gear ratio is too tall for 200mm tyres if you have proper hills, especially off road.
