I want to get 3 batterys in series. so first i will Change connections from the 5.5mm bullet to xt90 with some soldering and also and also change Focbox to xt90. (So it would handle higher currents)
Then I will use the 2 adapters to make a series connection,
I have a longboard if trucks don’t work with mount ill get caliber trucks i bought 90mm flywheels for easy pulley system and higher top speed.
Is there anything wrong with the build i’m planning I wan’t to buy soon.
Seriously man… Not trying to be rude or anything, but please read more and stop making new topics everytime you face something you dont know the answers to. You already have 3 other topics, made within the last 24 hours. Please ask in them instead
open up general chat… weve been answering questions like “what are the three wires for? pos, neg, ground?” for a few days now. he makes these threads when we get tired of answering them in chat
Focbox is meant for 60a continuous. Putting a xt90 would mean your connector can handle up to 90a however the focbox won’t change. But if all you are using is xt90 to connect everything that’s fine. Your charger probably has xt60 so u will need to make an adapter.
