My motor started acting weird after I taped the wires from the motor really close to each other. I have tested the motor before and had no problems. Also after I did the sensor setup. Does anybody have an idea of what’s going on?
I got the 6355 motor from TB and vesc from them as well.
So motor detection is running through without issues right?
If you spin your motor by hand it’s like before free spinning or is there some resistance?
Like @brenternet said check also that there no exposed parts on your bullets touching each other.
Check your screws which hold the motor to the motor mount. If they too long you can short the phase wires inside the motor as well
@Andy87 I can try to run the motor detection again, but I’m afraid if the motor will start smoking. Motor spins freely like before. Screws are 10mm so shouldn’t be an issue.
@torqueboards Do you think I can run the sensor setup again without the motor starts smoking?
Got the problem fixed. All I did was run the sensor setup again, change sensor mode to “Sensored” and “write motor configuration” and “write app configuration”.
Thanks for the help everyone! Didn’t know what to do without this forum!
Unplugged everything and back to the same issue. Connected everything again, ran sensor setup and it worked again. After you do the sensor detection you cannot unplug the sensor cable else you have to do the detection again. Is that normal @torqueboards ?
I’m not 100% sure… maybe someone else who runs sensored more can let us know. But for myself anytime I change any motor settings on FOC Sensored. I always run it again.
