Hey all,
So I’ve begun the process that is my first build. I’ve figured out what I’m going to be using for a lot of the non-electric parts, but I need some help determining my motor/battery combo. I’m going to run a single motor set-up on this first build to simplify things, but there a lot of options if you’re just going with one motor. Here’s what I need help determining.
- Motor kV rating
- Motor size (6374 vs 6355)
- Battery size/type I live in a relatively flat area and would like my board to be on the faster end (approx. top speed of 25 mph/40 kph). Range is not as big of an issue for me, but ideally at leat 10 miles/16 km would be appreciated. If anyone has a single motor setup that’s worked well for them, I’d love to see your work. Any and all thoughts are appreciated.
-MH
