Hey guys, one of the screw stuck on the motor can, is there any way to get it out except a sew to cut it?
I tried hex head and these phillips head. Both of them are not really working for me. (stainless steel)
Is there any screw head pattern and material of screw are less likely to get messed up from the head?
Thanks!
even better is torx if you have bits handy. Phillips were actually designed to strip to prevent over tightening and damaging threads. Torx will give you all thee power you need to TEAR the threads right out of that tapped hole the way god intended.
