I have a dropthrough deck
could still get something similar to this https://www.daddiesboardshop.com/khiro-drop-thru-shock-pad
How would this work?
have you attached pictures of your setup?
Reverse mount is longer. With basic mount you can’t get much clearance.
@Nikolas Yes, Tuomalar is correct. A reverse mount setup will be a bit longer that way you can have clearance against the truck baseplate. Of course, you don’t want a one size fits all otherwise the inward motor mount (under the deck) will be too long for clearance.
I was able to reverse mount one of your regular mounts, but clearance is very tight.
OK! Thanks everyone for the ideas!
