Hey guys so at low speeds in grass or pavement mostly grass my motors cog.Im wondering if their is a way to set it up for smoother acc.Its 8085 170kv sesored motors on a 11t-50t 225mm wheels.Trampa vesc6 esc.Could this issue be the kv is too high to run at slow speed?
Post your vesc settings
Are you running sensorless in the vesc tool instead of sensored or hybrid?
You have to run sensored FOC, there is cogging in sensored or hybrid BLDC mode.
I have this annoying cogging now too after the latest firmware update. I am not sure which firmware caused it though but 3.47 maybe
Your gearing seems a little off for such a large tire diameter, I could be wrong. Another thing that could be the cause of the cogging is a failed hall sensor. If your motorplates aren’t aligned or off a little in the wrong way, the can rubs against the sensors and breaks them. This happened to me on a 6374 170kv from improper alignment. I desoldered 2 of the 3 sensors and replaced them.
sorry guys for the late reply i will show my settings when i get off work.Its foc sensored with halls
