Hey guys!
So today i was about to install my new Focboxes.
I have an issue during the motor detection.
Motor spins up well in start of the detection but in the end of the detection it studders as crazy and detection fails.
No faults in terminal.
I can use the keyboard to control motor and that works perfectly.
Just wondering could this be due to a bad solder connection? Or is it something else im missing?
My other standard vesc 4.12 has no issue detecting with the same settings.
Can you please share your Motor detection tab settings and also it would be great if you record a video during detections?
Also tell us about your setup and are you using FOC or BLDC?
Your maximum input voltage is high, it must be below 50.4V I think,
Try lowering it and adjust the minimum and maximum accordingly and try performing a detection again
@barajabali please have a look to this one.
@Bjork3n If you purchased it from us then try downgrading the firmware and perform detections using Enertion’s BLDC tool.
