I reset every setting in the vesc tool after the motor stopped working suddenly and any input will short the phases, now it won’t respond to my signal, works with keyboard and motor detection in vesc tool. Any idea how to fix this?
Ok it suddenly works again for some reason, will update it it stops again
Have you gone through the input setup wizard and selected the control method?
Yeah, saved all the configs
And what is your control type set as?
mini remote, ppm I think.
I don’t think this had anything to do with app settings, I reset motor settings to default and it started spinning with input
Not like this then with it set to off? Should look like this. Worth checking the ppm tab then control type.
Oh, I’m using current no reverse with brake
I think I know what happened, after the motor stopped working I couldn’t get the hall sensors to detect, so I think it broke and I forgot to reset the settings to sensorless
That sounds right then. Worth running through the input setup wizard again and enable current no reverse with brake on both tabs.
