Now when I pair the remote the motor stars going in reverse without me pulling the trigger and when I trigger the pulling the motor stops until I release the trigger and then the motor starts to go in reverse again.
Any Idea what it could be the problem? ESC? Remote?
Sounds like the neutral spot has been lost/changed. On the VESC you can set it in the config, on some ESC’s you have to calibrate the remote. What’s kind of speed control or are you using?
Finally I follow the instructions of the video an I fix it It was really simple.
Any way I’m going to buy the programmer card because I have to modify the acceleration, now my skate goes like a wild horse just by pulling a little bit the trigger.
