Hey there, just finished my build and came to take it for a spin and the motor was going in reverse. Anyone know what’s wrong?
Are you using a VESC? If not just swap two phase wires.
Switch any two of the 3 motor wires and run motor detection again
even if you are using a vesc…just switch the position of any 2 of the 3 phase wires
If using a VESC it’s just a box you tick. You can switch one wire but then you’ll need to do the motor detection again.
ah…TIL…i havent used the vesc software i still use the bldc tool
Now that I think about it it’s only while running FOC that you’d need to redo the motor detection.
Is there a way to reverse the motor rotation using software? Switching the phase wires seemed like a hastle.
I know there is a box to tic on the Vesc-tool firmware. Dont think so on the BLDC tool
Thanks, I just had the phase wires plugged in incorrectly.
