Motor has stopped moving
okay, so i was going for my 3rd ride, when my esk8 randomly started cutting out. after observing this i stopped riding and walked home. My batteries were very low, but i recharged them and they seem fine because everything turns on when i plug in. another culprit may be the motor, for i hadn’t fastened down the motor pulley enough and it scraped a bit on the outside. suspect 3 - by this time the motor had completely cut out. The vesc may be to blame. i realised as i turned on the Vesc, there was a red light that flashed three times, and as i pressed the controller no white light came on. when i turned the vesc off, a red light flashed once. Also, i tried doing “start detection” on the BLDC tool, and it came up with “Bad Detection Results recieved” .Thanks for reading, Is there a way to fix?
Thanks, xXKOTOXx
put the vesc on the pc and do the bldc …motor test
@Hummie did the “start detection” and it comes up with “bad detection”
then I bet your vesc is probably fine and the motor is not.
Seems not vesc problem, but either battery or motor. I think its battery issue. If you use lipo and drained them completely, although its charging will never last a minute to ride.
check your motor leads and make sure they are well insulated and not touching. look inside if you can and see.
@Hummie Thoughts? what do you think i should do.
are your batteries up to voltage ? maybe you can fail the test with low batteries.
its hard to tell if a motor is shorted. a multimeter is rarely accurate enough. you can get an inductance meter for like 12bucks and they’re really accurate.
what do you think the red flashing means
i think it’s in the bldc program. and then the terminal tab and literally type faults. I think
Well first things first:
Can you go to the Terminal tab after you got a failed detection and type faults there.
ill send a video
How @flatsp0t
Do a motor detection again, let it fail. then go to the Terminal tab, type faults in the text box and click send.
Fault : FAULT_CODE_DRV8302 Current : -0.8 Current filtered : 0.0 Voltage : 31.41 Duty : 0.02 RPM : 0.0 Tacho : 1 Cycles running : 4 TIM duty : 866 TIM val samp : 441 TIM current samp : 23107 TIM top : 45331 Comm step : 2 Temperature : 29.18
Fault : FAULT_CODE_DRV8302 Current : 0.5 Current filtered : -0.1 Voltage : 31.42 Duty : 0.02 RPM : 1.0 Tacho : 2 Cycles running : 3 TIM duty : 991 TIM val samp : 523 TIM current samp : 22415 TIM top : 43784 Comm step : 3 Temperature : 29.15
Fault : FAULT_CODE_DRV8302 Current : 0.3 Current filtered : -0.2 Voltage : 31.41 Duty : 0.03 RPM : 1.4 Tacho : 3 Cycles running : 4 TIM duty : 1160 TIM val samp : 609 TIM current samp : 21453 TIM top : 41687 Comm step : 4 Temperature : 29.18
Fault : FAULT_CODE_DRV8302 Current : -0.5 Current filtered : -0.4 Voltage : 31.42 Duty : 0.02 RPM : 3.0 Tacho : 6 Cycles running : 4 TIM duty : 991 TIM val samp : 523 TIM current samp : 22415 TIM top : 43784 Comm step : 1 Temperature : 29.20
Fault : FAULT_CODE_DRV8302 Current : -0.0 Current filtered : 0.3 Voltage : 31.41 Duty : 0.02 RPM : 1.9 Tacho : 7 Cycles running : 3 TIM duty : 834 TIM val samp : 442 TIM current samp : 23299 TIM top : 45714 Comm step : 2 Temperature : 29.20
Fault : FAULT_CODE_DRV8302 Current : 0.4 Current filtered : -1.0 Voltage : 31.42 Duty : 0.02 RPM : 2.0 Tacho : 9 Cycles running : 3 TIM duty : 792 TIM val samp : 421 TIM current samp : 23542 TIM top : 46242 Comm step : 4 Temperature : 29.12
Fault : FAULT_CODE_DRV8302 Current : 0.1 Current filtered : -0.5 Voltage : 31.42 Duty : 0.02 RPM : 1.9 Tacho : 10 Cycles running : 3 TIM duty : 991 TIM val samp : 523 TIM current samp : 22415 TIM top : 43784 Comm step : 5 Temperature : 29.25
Fault : FAULT_CODE_DRV8302 Current : 1.0 Current filtered : -0.3 Voltage : 31.42 Duty : 0.00 RPM : 0.1 Tacho : 11 Cycles running : 1 TIM duty : 263 TIM val samp : 10 TIM current samp : 26384 TIM top : 52747 Comm step : 6 Temperature : 29.25
Fault : FAULT_CODE_DRV8302 Current : 0.6 Current filtered : 0.5 Voltage : 31.45 Duty : 0.01 RPM : 0.1 Tacho : 12 Cycles running : 1 TIM duty : 554 TIM val samp : 297 TIM current samp : 24879 TIM top : 49165 Comm step : 1 Temperature : 29.49
Fault : FAULT_CODE_DRV8302 Current : 0.2 Current filtered : 0.5 Voltage : 31.39 Duty : 0.02 RPM : 1.1 Tacho : 13 Cycles running : 2 TIM duty : 792 TIM val samp : 421 TIM current samp : 23542 TIM top : 46242 Comm step : 2 Temperature : 29.44
Fault : FAULT_CODE_DRV8302 Current : 0.3 Current filtered : -0.2 Voltage : 31.39 Duty : 0.36 RPM : 0.0 Tacho : 14 Cycles running : 1 TIM duty : 3705 TIM val samp : 755 TIM current samp : 5903 TIM top : 10296 Comm step : 3 Temperature : 30.47
Fault : FAULT_CODE_DRV8302 Current : -0.1 Current filtered : 0.1 Voltage : 31.39 Duty : 0.60 RPM : 300.3 Tacho : 16 Cycles running : 378 TIM duty : 3999 TIM val samp : 1999 TIM current samp : 5332 TIM top : 6666 Comm step : 5 Temperature : 30.41
Fault : FAULT_CODE_DRV8302 Current : -0.2 Current filtered : 0.1 Voltage : 31.45 Duty : 0.36 RPM : 1.0 Tacho : 17 Cycles running : 2 TIM duty : 3702 TIM val samp : 1846 TIM current samp : 7010 TIM top : 10329 Comm step : 6 Temperature : 30.47
Fault : FAULT_CODE_DRV8302 Current : -1.4 Current filtered : 0.4 Voltage : 31.41 Duty : 0.02 RPM : 0.0 Tacho : 21 Cycles running : 2 TIM duty : 903 TIM val samp : 10 TIM current samp : 26384 TIM top : 52747 Comm step : 4 Temperature : 30.76
Fault : FAULT_CODE_DRV8302 Current : -0.2 Current filtered : -0.3 Voltage : 31.44 Duty : 0.01 RPM : 0.0 Tacho : 22 Cycles running : 1 TIM duty : 554 TIM val samp : 297 TIM current samp : 24879 TIM top : 49165 Comm step : 5 Temperature : 30.76
Fault : FAULT_CODE_DRV8302 Current : -0.5 Current filtered : 0.7 Voltage : 31.38 Duty : 0.03 RPM : 1.4 Tacho : 23 Cycles running : 5 TIM duty : 1160 TIM val samp : 609 TIM current samp : 21453 TIM top : 41687 Comm step : 6 Temperature : 30.70
@flatsp0t know what it means?
Well, that is not that good. Seems like a fried DRV. This could be caused by either a short, or a setup/configuratin problem.
May i ask where you got the VESC from and When?
recently bought, diyelectricskateboards
Well, then it is not the Firmware bug i thought of, so i would try to examine the reason and check for shorts. if there are none, it is most likely a configuration issue.
Anyways, you need to get your Vesc repaired. Maybe ask @torqueboards if he is willing to help you wit this, if not and you are in the US/Can you can ask @JohnnyMeduse to repair it, he is the uncrowned king of dead(and ofc. repaired) DRVs.
@flatsp0t sorry - im a noob. what is a drv
