Hey guys,
I’m an engineer from Germany and I developed a dual motor mount for Trampa spring trucks. Looks like this:
- truck adapter ring and rods from 7075 aluminium
- motor plate from stainless steel
- fits 63 motors up to 10mm shaft
- adjustable mounting angle
- dual idlers for high gearing reduction
I have 4 sets for sale but can produce them again if the interest is there. Unfortunately I cannot run the latest version my own because I’m still waiting for the right belts…
But latest prototype looks like this:
Changes from there to the final version:
- length of the motor plate reduced by 10mm
- motor plate a bit thinner
Some more pictures of the mount:
Also I designed some pulleys for the Hypa wheel. Looks like this:
Details:
- variable size (everything from 64T up is possible.
- 60mm M4 screws to use with the original nuts
- meant for 15mm belts but wider wouldn’t be a problem
- printed with PLA+
The files for the pulleys will be available on thingiverse soon. If you need someone to print, I can to that for you
Prices
- 125€ for the complete motor mount with idlers
- 15€ per hypa pulley
Message me for your desired gearing, I might have the right belts for you as well!
Cheers!
