Hi. I have a vesc that I got from Ollin board last year, it broke at the beginning of the summer and I sent it back under the warranty for a free repair.
Now after almost three months without it(!!!), I finally got it back. But after plugging it in to do the motor configuration it had the same error. I don’t wanna have to send it back since that took way to long and don’t really have the money for a new vesc. Is there something that I can do to reset the faults since I can’t see any burn marks on the chip.
The vesc is running fw 3.102 in BLDC mode. When powered up but not trying to rotate it does not give me any error but when trying to run this is the error I get:
and here are the settings:
Is there some setting that is wrong? I noticed in the terminal window that there is a drv reset but the command is not found…
Thank you!
