Hello everyone, my first post here, and also my first post in my non native language.
So first of all, I am finishing my eboard righ now, I don’t have a lot of money , so I have buyed cheap parts.
The motor is a 6368 280kv, and the ESC is a racestar 120A. powered by 6s.
The problem is in the motor, and only happen when I am stop, once I am moving it has a lot of power. It is not a problem from the best. my gear ratio is 15/40
I think that it will be a problem of high kv of the motor it self, also it doesn’t have a lot of power of braking. Thats a esc problem I gues
I think it is just a bit of motor cogging but I can’t be sure, this will happen on senseless setups sometimes, and even sometimes with sensors. The way to fix this is to give the board a little kick push to get it moving and then hit the throttle. The kick push will not only prevent the cogging, but ultimately save you a bit of battery life. You could also try switching the phase wires around to get a smoother start up but this probably won’t help very much although it is worth a shot.
As @Smorto said, you need to push off manually and then hit the throttle.
Switching your motor wires around won’t help and could cause your motors to run reverse direction.
